RC Rock Crawlers The official rock crawling forum right here on RCU. Rock Crawler Trucks Rule!
txt axles
Old 01-25-2007, 03:59 PM
RcDrivinFool
Default txt axles
i am looking to build an rc crawler and at first was going to use tlt-1 axles but when i realized how narrow they were i decided on txt axles but i dont want to buy a whole truck and i dont want to use clod axles. i thought i could just buy aftermarket axles but it would be cheaper to build stock axles and upgrade them from their.
Old 01-25-2007, 09:40 PM
dezfan
dezfan's Avatar
Default RE: txt axles
If your wanting a 2.2 crawler the TLT axles are fine. If your wanting a super, the TXT axles will work OK, but the super class is dominated by the Clod.
Last year at the Nat's, Of the entire Super field there was only 1 for sure, maybe 2 total in the entire field. None in the top ten I don't think.
Top 5 were all Clod for sure.
Old 01-25-2007, 11:25 PM
rcxboy
rcxboy's Avatar
TXT is very scale though, it'd make a good looker and basher.
Old 01-25-2007, 11:30 PM
Acs_guitars
Acs_guitars's Avatar
Didn't JIA use Juggy/TXT axles on Ralph at one point? Or am I thinking of another rig I saw on RCC......
Old 01-26-2007, 12:27 AM
dezfan
dezfan's Avatar
No, Ralph started w/ TLT and is now using WK axles.
His Scorpion uses TXT axles.
Old 01-26-2007, 12:32 AM
Acs_guitars
Ahhhh... the Scorpion!! He has so many I get them confused. I saw the WK build up and it looks better than ever!
Old 01-26-2007, 07:37 AM
RcDrivinFool
im not looking to build a super truck because i live along way from any events we have but i did want some axles that were slightly wider than the ones on the tlt-1 for stabillity and the fact that icould make the truck look more scale and run a stampede tranny instead of having to go through all of the extra expense of buying two of everything motors, pinions and so on but my main question has not been answered i still need to know what the parts bags are be cause i would rather not spend my money on 400 dollar aluminum txt-1 axles because idont need them
Old 01-26-2007, 09:45 AM
dezfan
dezfan's Avatar
Not sure on the TXT as I stated, they are not very popular.
You can pick up the ENTIRE TLT kit for $70.00 from www.ultimatehobbies.com
Also, several companys offer wideners kits for under $25.00.
Here is a shot of my 1/10 scale CJ8 w/ TLT axles.
ID:	606899   Click image for larger version
ID:	606900   Click image for larger version
Old 01-26-2007, 03:21 PM
RcDrivinFool
what all do you have on your tlt-1 because what you are building is along the lines of what i want except i want to build a mini versio of my uncles defender
Old 01-26-2007, 05:50 PM
dezfan
dezfan's Avatar
All you really use is the axles and misc. hardware from the TLT kit.
But the TLT fit perfectly under a 1/10 build.
Old 01-26-2007, 08:10 PM
Anomie
Anomie's Avatar
dez, you come up with the coolest pics [:-]
Old 01-26-2007, 08:13 PM
dezfan
dezfan's Avatar
ORIGINAL: Reiko
Thanks, that's my scale CJ8 build w/ the Reign Industries K2-3S chassis, One off tires, RC4WD bead locks and a simi rare Pro Line CJ8 body!
Old 02-01-2007, 07:29 AM
RcDrivinFool
another reason i want to run txt axles is that rc4wd makes a set of portal boxes that replace the txt1 knuckles and give almost an extra inch of ground clearance
Old 02-01-2007, 02:52 PM
dezfan
dezfan's Avatar
ORIGINAL: RcDrivinFool
They also build them for the TLT axles!
