stripped heads
stripped heads
can ne1 tell me how i can get out a screw that has had the head chewed up real bad
i tried useing thread lock to fix a driver in but still no joy
NY
RE: stripped heads
which screw are you talking about. if you can get a small pair of channel locks and try to get it out. try jamming a star driver in there. there is this tool you can get, probably at a hardware store or somthing of that nature where it's like a drill bit that goes into a atripped screw and you turn it counterclock wise and it will get any stripped screw out, they come in different sizes, large med small. i have the small one for my rc stuff
NY
RE: stripped heads
here this things comein handy ALL the time
use the first thing the spiral screw extractor http://www.mytoolstore.com/hanson/extractr.html
QC, CANADA
RE: stripped heads
This is what i use. One side makes a new and clean hole and the other side bites onto it while turning in reverse. Never met a screw that wont work with it. Only thing is its a mastercraft brand and its sold in canadian tire stores only. If anyone really wants a set i can allways ship some out.
NY
RE: stripped heads
you just have to get a bit that a little smaller than the wasy out. drill right in the middle of the screw and then put the easy out right where you drilled then tap it and begin screwing counter clockwise
RE: stripped heads
Get a drill bit about the size of the thread part of the screw drill the head of once you get it apart take a pair of vise grips to get the remainder of the screw out. This is providing where the screw is.
