Threaded rod 4-40 Double
Hi All,
Somebody could find out where I can buy DOUBLE THREADED ROD 4-40, because I am trying to do thread on the other side, in a small rod of DU-BRO 4-40 with dies but the link doesn't screw. And this way I find easier to buy the ready piece.
Thankful for the attention
Sergio(Joca)
Hi Kdc,
Cam this be made for big airplane ??
I am finishing the construction of CESSNA 150 (hostetler )
Thank you for help.
Sergio(Joca)
There is a reason it is hard to find. If both ends are threaded it can easily come apart due to vibration. One end threaded and the other silver soldered, "Z" bent or with a 90º E/Z Link is better.
Here are shorth lengths for attaching to the end of Sullivan hollow rods.
http://www2.towerhobbies.com/cgi-bin...?&I=LXFV02&P=7
I use all-thread 4-40 rod in varying lengths cut to size, and stiffen it with carbon fiber tube bonded to the rod with j-b weld. I leave enough threads exposed at each end for a metal clevis and binding nut.
Buy some 1/8 inch noncoated welding rod and two dies, a 5-40 and 4-40. Cut to length then threade both ends with the 5-40 die then chase them with a 4-40 die.
You are right to be cautious if it is a big plane. The Z bend at one end seems a better way.
However another way to join 2 rods is to insert them into a piece of thick wall brass tubing and solder them. A slot or a notch can be used to allow solder to penetrate.
My Feedback: (40)
NH
Joca, something makes me think you're looking for left-handed and right-handed threads on the ends--something along the line of the Hangar 9 Pro-Links. If that's the case, cutting the threads yourself is probably the best solution. Rodney's suggestions would apply. If there's not a toolroom supplies superstore in Brazil, you can probably get the dies at McMaster-Carr.
Hi Majaortom-RCU,
Here in Brasil the importer not to buy several produsts for the modelairplane and with when we needed have to buy direct to the web pages. But I thank the greats help.
Thanks for the help
Sergio(Joca)
ORIGINAL: Rodney
Just Google "Rod Chuck" for some info on making your own threaded rods.
McMaster also stocks nylon self tapping nuts in small sizes...I use them in addition to the steel nuts to help with vibration.
