Firewall of GeeBee-Z ARF is not parallel with wings. How can I install the engine???
On my GeeBee-Z, the wall onto which the engine mounts will be installed is not parallel with the wings, i.e. the left side of the firewall is slightly more foreward than the right side of the firewall. This would cause the engine shaft to be pointed to the right. What's the best way to bet the engine shaft pointing dead ahead center?
AND....is there some kind of device I can use to test how well-centered the shaft is?
