E conversion help
OH
E conversion help
I am building a 40 sized dazzeler for electric and I want to run one of great planes's rim fire out runner motors. The two I am looking at are the 42-60-480 and the 42-60-600. Which one would you reccommend as well as the battery and prop combo to generate the most thrust. According to the motor's website the 480 will swing a bigger prop but is recommended for a 5.5lb 3d plane. The 600 swings smaller props but will fly a 6.9lb 3d plane. I think there is some trick in understanding RPM/V ratings in accordance with prop size in order to get the best performance too right?
Appreciate the advice,
Alex.
Alex.
RE: E conversion help
ORIGINAL: rcmaster-RCU
Alex.
Alex.
The next question would be what battery you are going to use? Actually that is the most important question because the battery limits the maximum current and voltage you have to work with. this sets the maximum watts or power you can supply to the motor. (Voltage times Amps equals Watts) Once I know that I can give you a better answer. I will need the battery capacity, the cell count, the c rating and the manufacturer.
OH
I am thinking a Thunder Power Extreme 5 cell single pack 4500mah with a 20C rating. You say the Rimfires are on the mid spectrum of performance. What type or brand of outrunners are on the high end of performance? I have two rimfires and really like them so I was just sticking with what I know. Can a better outrunner deliver more efficient power and still be the same weight and size as other motors?
Thanks for the reply,
Alex.
Alex.
Alex.
Alex.
Now to answer your questions about motors. Since you are going with a 5 cell battery and we will assume 20c. I like to stay reasonably conservative so we will work with 15C. For this we will work at 45-55 amps. This gives you 18.5 volts at 45-55 amps which is 832-1017 watts. Assume 95% gets to the motor or 800 to 1000 watts give or take. Since the dazzler is a 3D aircraft, I would go with the lower Kv motor so you can run with a bigger prop and get more thrust at a lower speed. Since I would want to go withthe motor that has the lower Kv. For 5 cells I would want a 450-500 Kv.
