RC Rock Crawlers The official rock crawling forum right here on RCU. Rock Crawler Trucks Rule!
Metal: Bend dont bust
Old 02-19-2007, 08:52 PM
Jatoff-roader
Default Metal: Bend dont bust
OK, this is a question.
What is a good metal I could bend up a 1/2" x 1/2" up @ a 90' angle?? not a large peice just a small vertical surface.
I hear 6061-t6 is hard to bend unless heated or frozen (lol frozen???) I need it to be barely flexible but i could bend up w/o breaking or cracking. I need it to be relatively cheap also only need 1sq foot. ONLINEMETALS.COM no more than 10-12 bucks. Thnx guys any imput would help alot.
Old 02-19-2007, 08:57 PM
Anomie
Anomie's Avatar
Default RE: Metal: Bend dont bust
2024 or 3036 aluminum will be easier to bend. Also, the thinner, the easier.
Old 02-19-2007, 09:10 PM
Jatoff-roader
But it will bend i need 3mm -4mm aluminum dosent NEED to be easy to bend just possible..., and no cracks.
oh and 2024 is EXPENSIVE!!!!!! 30.00 bucks!!!!!!!!
Old 02-19-2007, 09:13 PM
Jatoff-roader
what about 5052 h32???????
Old 02-19-2007, 09:18 PM
Acs_guitars
Acs_guitars's Avatar
6061 0 is fairly easy to bend. And cheap - - I believe it is what Home Depot carries
Old 02-19-2007, 09:22 PM
Jatoff-roader
If you read some of the fourms @ rccrawler you will find that it cracks whaen it bens that may reduce durability.
Old 02-19-2007, 09:40 PM
Anomie
Anomie's Avatar
Perhaps I am wrong.
Old 02-20-2007, 12:00 AM
Acs_guitars
I -ALWAYS- use heat when bending any metal, unless in a break press. It makes for a smother bend. You also have to keep in mind the thickness of the material being used.
Old 02-20-2007, 04:27 AM
xtremraptor
My Feedback: (24)
xtremraptor's Avatar
anytime you stretch a metal, which is what you are doing when you bend it, is going to cause that spot to become weak.
the molecules of the metal on the inside of the bend will be compressed and the molecules to the outside of the bend will be expanded. might not seem like it would be that much on a 4mm thick peice but it still spreads the material and makes it weaker
Old 02-20-2007, 07:45 AM
Anomie
Anomie's Avatar
It will also help to use a 'nose' piece to assist the bend, at whatever radius is necessary. This is especially true for a box brake. I've found that bending the softer aluminum in a vise and over a guide will work pretty well too. If the finish isn't critical, that is, or if it is to be painted.
Old 02-20-2007, 08:14 PM
Jatoff-roader
ok, Can i bend 60-61 w/o it becoming weak to the point it will break easily?
