G-26 Engine Mounting
Hi all. I will be mounting my first gas engine ( G-26 ) shortly and would like some suggestions as to the best way to go about this as it is totally different than my glow engines.
Thanks P. J
Thanks P. J
My Feedback: (10)
RE: G-26 Engine Mounting
p.j,
You'll have to use "Stand-Offs" which are nothing but a round spacer made of aluminum or wood with a hole through the middle allowing a bolt to pass through. These are made to the length you need to have your spinner backplate at the proper distance from the cowling. Here is an example.
http://www.litepilots.com/enginestandoff.htm
My Feedback: (62)
UT
But... you'll only need stand-offs if you need to move the engine forward for cowl clearance. I have mounted a few G26's with only spacers to give the correct thrust angle. The attached picture shows this better.
Thanks for the info. guys. I was wondering about using blind nuts on inside of the firewall the same as for glow engines . The flat mounting plate on the back of the 26 has four threaded holes in it leading me to believe the boltheads should be on the back of the firewall , is this the nonmal way to put the bolts on a gas engine , not very convenient .
Thanks P. J
Thanks P. J
My Feedback: (62)
UT
I prefer blind nuts on the inside myself. The flat plate I have doesn't have threads as it was modified from the original. I don't like having to go inside the fuse to mount an engine either. I've done it a few times but don't prefer that method.
