plastic rotor screws?
Greetings,
I put new rotors on the DF-IV I just got, and found that the screws were too short. In comparing the old gears to the newer gears, I see that the old ones are only threaded at the bottom of their holes, not all the way like the newer gears are. The new rotors seem to be just a bit thicker than the old foam ones, and the screws just barely catch. To fix this for now, I just used 1/2" metal screws.
This leads me to the question of why we use plastic screws. I've read a number of reports about sheared screws, and people buying mass quantities of replacement screws. Aside from the nano-gram of weight difference, is there any reason DFI doesn't just use metal screws?
Rusty
Rusty
RE: plastic rotor screws?
I would agree with that logic if they only sheared on impact with some solid object, but I'm sure I've read of a number of them shearing in flight.
Rusty
Rusty
Yep, been there, sheared that. But in my case, it was probably due to rotor frame strikes, so I guess that counts as hitting a solid object. But ever since then, I've been running brass screws.
Will
Will
I just got a set of skookum carbon fiber blades from Germany - (2 blade not 3) - they are so tough that i'm kinda glad i have the Nylon screws for right now - however they have been striking the frame as much as the stock black ones, so to lessen this problem i took an old DVD case and cut out 2 spacers for each blade therefore raising the blades just enough that they don't do it as readily anymore. - sorry bit of an off shoot there, but bottom line: Plastic screws good with CF blades.
ON, CANADA
If your still practicing/hovering and hitting stuff, yep nylon. If you're flying outside and getting frame strikes now and then, time for the brass screws. Especially with CF blades, don't risk a crash and expensive repair 'cause the nylon screws sheared off, better to have confidence that the blades will stay put.
Just my .05 cents
Just my .05 cents
Thanks for the comments. I guess the flexible rotors, and plastic screws are a good choice for starters, then you can decided if you think the metal screws are better.
Cheers,
Rusty
Cheers,
Rusty
NC
I had the DF in the great shipping box and from CAN to NC it sheared one of the screws, in the case! I had to do a repair as soon as I got it back from DFI. I am sure it was a once in a life time...Denny
