marchetti sf260 views/plans wanted
ON, CANADA
good day everbody, i came across some pictures of the marcharetti (spelling right?) sf 260. i wish to design & build a scale model of this craft. possibly making fiber cavity mold to obtain the final shell.
but i need somewhat acurate exterior 3 view drawing & sections or plans. the only downloadable plan i found was for a profile model & 30 sized.
if u have a usable plan
once i can get reliable views, i'll be able to draw out some good plans. thinking of a 90 sized model.
[email protected]
[email protected]
My Feedback: (60)
AZ
Scale R/C Modeler had a set of plans available that were extemely well done. The magazine is gone now and I don't know if the plans are available from another source or not. I do have the magazine with a reduced copy of the plans that I could scan for you if you wish.
My Feedback: (60)
AZ
Turns out the article in Scale R/C Modeler is for the F8 Falco rather than the SF260. The Falco is essentially an all wood homebuilt version of the SF as can be seen below. The plans in SRCM were done by Robert Sweitzer who has since passed on so I doubt you can purchase them new. The RCM plans are probably a better bet.
ON, CANADA
thanks for the info, chad. was it u who spoke of the rcm mag plans u could scan? i think i could still gain good fuse info from it although i still intend to go for the sf-260 (i like those tip tanks)
& thnx to everybody for your info. i'll still try to scrounge around for info. later guys
reaaz
reaaz
