Festo Filter Help!!!!!!!!!
Hi All,
I need the festo code for this filter, I can not buy them here in Chile if I do not know the code, so please help!!!!!!!!!!!!!
ON, CANADA
RE: Festo Filter Help!!!!!!!!!
Hi Airbuspilot,
Are you looking for a filter to fit 4mm or 6mm Festo tubing? The codes are slightly different depending on the tube size.
ORIGINAL: rcav8tr
Hi Airbuspilot,
Hi Airbuspilot,
Hi Airbuspilot,
Believe Festo only do a 4 or 6mm filter of this type...
http://www.festo.com/INetDomino/files_01/275320B.pdf
Eric
Correction! They do a 3mm...
https://enep.festo.com/irj/servlet/p...ep_customer_gb
Eric
Hi Fernando,
If you find a way of fitting 3mm tubing to that filter please tell me ! It's actually made for 3mm ID and 3mm OD will not fit . I've tried . I'll be in SCL a number of times this month . Want to go flying ?
Marc
Marc
ORIGINAL: airbuspilot2
I am looking for 3 mm but thats ok I underdstant that code will be VAF-PK-3
ORIGINAL: rcav8tr
Hi Airbuspilot,
Hi Airbuspilot,
ORIGINAL: 747drvr
Hi Fernando,
Marc
Hi Fernando,
Marc
ORIGINAL: rcav8tr
Hi Airbuspilot,
Hi Airbuspilot,
