A10X or Easyjet settings
Hello,
I would like to buy the Easyjet from digitech.
I have read a lot of post about this plane and it would be nice to have the best settings for this plane.
Many guys here own an A10X, It would be great to post your settings after 10 or 20 flights....
Thanks a lot
Jean Fi
Thanks a lot
Jean Fi
RE: A10X or Easyjet settings
ORIGINAL: jeanfi
Hello,
Thanks a lot
Jean Fi
Hello,
Thanks a lot
Jean Fi
Hello is Digitech
listen to me carefully i will only say this once...
1 we did over 100 flights with Wren 44 and SS engines
2 so i think we now where and about the perfect CG and trows are
3 englisch and german manual are specialy written for the Easy jet... (Digitech version)
4 we dont have the a-10 model variants ours is different and has different landing gear parts (Jet-1A)
BR Sandor
ps: at the moment we are testing :
Velox (29 flights)
and the new L-39 from Fei bao (0 flight currently building)
we wont sell it until I have flown it and we found the perfect settings and building instructions...
Hello DIGITECH,
Thanks for the answer !
I live in France and I sent you an email to ask you if you could sell me the Easyjet with the retracts combo including the Full oleo struts from JET 1A (you call it Deluxe retracts set).
The price of the combo without Deluxe retracts is 799€.
If you tell me this combo (799€) is strong enough for a good quality grass field I will be ok.
Do you have the easyjet and the retracts in stock ?
JeanFi
JeanFi
ORIGINAL: jeanfi
Hello DIGITECH,
JeanFi
Hello DIGITECH,
JeanFi
Jean,
I had over 50 flights on my A-10x. You don't have to listen carefully, because I'll explain it as many times as anyone needs
CG- 100mm from leading edge at root
elev- 1/2" low 1" high
ailerons- 1/2" low 1.5" high
Flaps- take off-not needed but I set mine at 15 degrees, landing-45 degrees. I had to mix some up elevator (1/8 inch or so) with mine...
Elevators are touchy so be careful on that first flight! You'll fly this airplane so much, you're going to wear the tires out.
Raf
Raf
HEllo Raf,
Thanks for the answer.
You say you set elevator at 1" high and you say it is touchy ? Isn't it too much ? Do you use expo on elevator ?
For flaps this is a good advice I will mix some up elevator at 1/8 inch !!
Jeanfi :-)
Jeanfi :-)
