Solvent for epoxy
NJ
I have been using acahol to clean epoxy out of my brushes when I fiberglass. Either I am not cleaning them enough or the achaol is not the best cleaner to use. I know you can use it to thin epoxy Thanks for the help
When using thinned out epoxy to fuel proof things I have found that the best way to clean the brushes is to throw them in to the garbage can. [sm=wink_smile.gif]
I buy a package of 10 disposable 1/2" brushes from the local hardware store for ~$4.00 and I don't look back.![Big Grin](images/smilies/biggrin.gif)
Life is too short to worry about the little stuff!
My Feedback: (13)
You can find 90% alcohol in your local drugstore. You may have to ask for it though, as a lot of places keep it behind the counter. Around here we have to ask as they will not usually put it on the shelves. ???? Also, FWIW, MEK (Methylethyl Ketone) is used as a solvent for epoxy. If you use MEK, use gloves as it is easily absorbed thru the skin.
TN
The best solvent for cleaning brushes is acetone that is what i keep my brushes in all the time . Squeeze out all the epoxy you can then drop your brush in acetone and leave it in the acetone . Also best if you use a air tight container . Bob
My Feedback: (108)
For thinning epoxy you want to find 99 percent pure alcohol. The water in the lower levels of alcohol will not allow the epoxy to cure correctly. I find a 99 percent pure at my Safeway. As for brushes, I have to agree that the disposable brushes are the best. I get them at my local hobby shop for .35 each. Cleanup is a snap. Good Luck, Dave
