Vulcan Diffs?
Vulcan Diffs?
I just got the Trinity 095 to put in my Vulcan. think I will blow the diff right away? How are the IRC Vulcan Metal Diffs 32002. Or any other suggestions for things that will break. Do you have the 32002 Diffs (metal) in stock?
thanx Chris
thanx Chris
RE: Vulcan Diffs?
You will probably blow the plastic diff gears in the Vulcan when you put that 095 engine in. THis is only a guess.
Regarding stock status, if you are looking to purchase directly from IRC, please email [email protected] for website stock status.
RE: Vulcan Diffs?
ORIGINAL: RC-BOSS
Hi,
But which parts should I use? Which parts do you recommend I get from your parts to make this stronger?
thanx Chris
RE: Vulcan Diffs?
ORIGINAL: RC-BOSS
You should start by putting in the front and rear complete differentials with metal gears.
Can you give me the part numbers?
thanx
