Not moving straight
Not moving straight
Hi guys I have a TC4 and the thing is wheels are not spinning on a definite direction. They are like making 8 shapes so that the car cannot go on a straight line. I changed my wheels, axles and those small adapters but the result is same what am I doing wrong? the trim settings are checked over and over but the result is same.
Any ideas?
Thank you...
Any ideas?
Thank you...
RE: Not moving straight
have you tried giving throttle with the whole car held above the ground, and with no wheels attached? look closely at what is spinning properly and what is moving around... my guess is the bushings/ball bearings have gone loose
