E-Flite Helicopters Discuss the line of E-Flite mini and micro helis including the Blade CP, CP Pro, Blade CX, etc
blade cx pro
Old 03-15-2007, 11:56 AM
rjday100
Default blade cx pro
www.bladecxpro.com
Has anyone installed the upgrade kit from this site. I was wondering if it really did what they say it does. I would love to be able to fly my cx in a little wind.
Old 03-15-2007, 02:59 PM
ArrowNaughtic
ArrowNaughtic's Avatar
Default RE: blade cx pro
Those are repackaged Dynam vortex parts..........you can get them from www.bphobbies.com............ That guy has a good bidness going.......... but I think its getting harder for him to justify his twice the price garbage..... Buy them direct, then post on here and someone will help you!
__________________________________________________ ________________________________
Of all the things I ever lost..................................... I miss my mind the most!
Old 03-16-2007, 01:39 PM
makatron
yes thats true, bladecxpro is selling rebranded parts from other sellers and adding twice the price for same stuff
he is now selling upgraded white blades for blade cx but if you check miracle mart website you will also see those white blades as xtreme blades with lower price tag, DO NOT BUY FROM HIM UNLESS YOUR LIFE DEPEND ON IT lol
he is just doing business out of the ignorance of some new heli guys
Old 03-16-2007, 06:50 PM
rjday100
so the dynam vortex inner/outer shaft will fit the Blade CX(as well as the gear wheel)? As well as the shorter flybar? If those parts were all I wanted to replace on my CX, would I have to also replace my upper/lower blades? I love to fly my CX but I push it to its limits too often with hard stops and turns and it always clips the blades and falls to the ground. Would this upgrade fix that problem?
Old 03-16-2007, 07:17 PM
ArrowNaughtic
yes rjday............. the Dynam vortex inner and outer shaft are a direct replacement for the stock CX2. They are a little longer so you can't mix and match but definatly a solid fix if you are getting blade clack. The Vortex flybar also works well but you have to unscrew the lower half of the flybar link and replace it with the lower half off of your CX flybar. There are a myriad of posts on this subject...... ndoren, soloboss and neilt6 are the (in my opinion) experts on this subject.
My blades went right on the Vortex's hubs....no problems. Solid mod, good reports on it. Good luck!
__________________________________________________ _________________________________
