Comp Arf 2.6m Yak55-SP, any build threads???
My Feedback: (24)
RE: Comp Arf 2.6m Yak55-SP, any build threads???
ya there were two over a year ago I made many posts with pics showing rudder install and pipe work - dig deep and bring them back from the dead.
Been looking and haven't quite yet. So far it does not appear that there have been many, or any, dedicated build threads to the 2.6m 55SP.
Since I'm using a 115 in mine I'll need to put most everything forward and ideas for a means of doing that would be nice. Not critical, but would make things move faster. I absolutely will not use the C.A designed rudder tray unless here is no other way.
My Feedback: (69)
AR
The stock tray is not bad. I used it with 2 5945s, but used the air wild horns and unihubs and it worked out quite nice, but no way wanted to use their horns, etc on that setup. This is what I used and it worked great. IMO 2 5945s was plenty.
http://www.airwildpilotshop.com/More...product&id=292
This is the biggest 2.6 yak thread
http://www.rcuniverse.com/forum/m_17...tm.htm#1712546
My Feedback: (51)
Guy's
If u guy's want I have another 2.6m showing up at the shop next week with a DA 100 I could run a new build thread on her.
Here is one I found as well.
Silver there is a Build Thread for my 3.3 Yak on here
http://www.rcuniverse.com/forum/m_37...tm.htm#3764712
Ian
Ian
Thanks a bnch guys. I found the Flyinrazrback/Darcy/Vicster thread while you guys were posting. That's a long thread, I only made it to page 41 before coming back to here.
Flyinrazrback,
Thanks for the tip on the rudder servo installation. Using that I'll use the C.A box, but for certain not with their arm configuration.
Flyinrazrback,
