Bellcrank setup ?
My Feedback: (40)
Bellcrank setup ?
Hello , I'm trying to convert my carb linkage from cable to rod with a bell crank
. Was wondering if any one has pic's of thier setup's . I could get a look at ? i have a general idea of how its done just want to confirm the set up . Thank's Bill V.
My Feedback: (40)
RE: Bellcrank setup ?
Thank's otto, That's a clean lookin power plant you got there.I sould have mentioned that it would need tobe on the lefthand side i really don't want to move my servo. Thank's Bill V.
Bill, His bellcrank is on the left side. You must mean that your servo is on the right side. What kind of engine mounts you have comes into play with this too. Kevin has Speedworld mounts, they come with that bellcrank assembly. I'm using Bonsi mounts in my Rigger. I have my throttle servo on the right side of the R/box, so I went with a CC Racing bellcrank assembly. This setup will give you a straight shot with the pushrod from the servo to the bellcrank arm. CC Racing mounts come with this bellcrank, or (like me) you can buy it seperately. Yea, I know the Carbon Fibre throttle pushrod is overkill! LOL But I ran the C/F pushrod for the steering because it was 17" long and I didn't want it to flex - I had 3' of leftover C/F rod so I figured, WHAT THE HECK!! lol Brian
My Feedback: (40)
Brian, LOL i was lookin at it from the front !! Opp's . But your setup is what i was lookin for i fabbed up my own motor mounts . and want tdo the same with the bell crank. i'll goin to give it a try . i'll keep you posted thank Guy's Later Biil V.
