Wheel Wobble
NY
Wheel Wobble
I just noticed that one of my stock wheels wobbles like crazy at high speed. What can I do to correct it, if anything. Also, do I risk breaking anything by letting it go for now?
RE: Wheel Wobble
check the bead of ca glue around tire and rim...if there is a gap (tire pulled away from rim) use thin ca to bond it back to the rim. Use a small amount and slowly roll/ turn the tire to spread the ca.
Hope this helps you.
RE: Wheel Wobble
ORIGINAL: jcam54
man Benzzyo5 I need to type faster...you beat me again!
RE: Wheel Wobble
ORIGINAL: BicketyBam
NY
RE: Wheel Wobble
ORIGINAL: azzman
Yea benzzyo may be fast but his spelling and grammer suffers...[:-]
ORIGINAL: jcam54
NY
RE: Wheel Wobble
ORIGINAL: Polar_Bus
What exactly do you mean by "wobble" does it wobble side to side, or up and down?
RE: Wheel Wobble
Up and down, like it is not balanced.
