problem with engine
ID
problem with engine
yesterday i was driving my savage .21 up and down the road and as i took off down the road one time the truck lost reseption and ended up in a river. the truck shut off after filling the engine with water. after that happend i took the truck in the garage took the engine apart and got rid of all the water in it. after making sure all the water was out i put it back together and started it up and everything was fine i can drive it but the only thing wrong is it stall's when ever i floor it. i have run about 3/4 tank of fuel through it just puttin around but it still stall's when ever i punch it . can't figure out what is wrong
plz help
plz help
NY
RE: problem with engine
reset the neddles back to factory settings then lean out the high speed nedle 1/4 of a turn and lean out the low spped 1/8 of a turn. start by slowly giving it gas and gradually go up ro full throttle and keep it there for abour 2 seconds. repeat, then put on ground and continue doing this. if it's still sluggish lean it out. also change the gloe plug if you havent already
IL
like everyone has said set everything back to factory and retune the motor, then do what i did and go out to your LHS and pick up a fail safe. I had one do the same thing, but instead of it hittin water right away like yours, mine went across an interstate then hit a flooded creek.
