TROUBLE SHOOTING NEW SAVAGE X
WELL I JUST GOT A NEW SAVAGE X A FEW DAYS AGO AND ALL WAS WELL UNTIL SUNDAY. AFTER BREAKIN, AND TUNING IT WAS TIME FOR THE FUN STUFF. I RAN THE X THRU 3 TO 4 TANKS OF FUEL W\ NO PROBLEMS, BUT THEN I NOTICED WHAT SEEMED TO BE ONLY THE FRONT WHEELS GETTING POWER. WHEN THE TRUCK WAS IDLING I THOUGHT I HEARD A CLANGING WHICH INDICATED TO ME POSSIBLE CLUTCH ISSUE, HOWEVER WHEN I TURNED IT OFF, WITH THE BOTH BACK WHEELS ON THE GROUND AND TURNING BOTH FRONT WHEELS IT ACTED LIKE A CHAIN SKIPPING ON A WORN SPROCKET. SPUR GEAR IS GOOD AS WELL AS GEAR ON THE MOTOR. I THINK IT MAY TRANSMISSION BUT NOT SURE WHERE TO START. ANY THOUGHTS ON WHERE TO START, OR SOMEONE W\ SAME PROBLEMS PLEASE LET ME KNOW.
RE: TROUBLE SHOOTING NEW SAVAGE X
THE REAR DIFF IS ALSO ON MY LIST OF POSSIBILITIES, JUST NOT SURE WHICH IS THE WEAKEST LINK BETWEEN THE DIFFS, TRANSMISSION, AND THE CLUTCH.
ORIGINAL: bb942
well diffs are prolly the easiest to check, dont have to take the truck completely apart. i doubt its the tranny.
and please turn your caps loc off. All caps is considered shouting on the internet.
PA
im gettin a savage x for my b-day on the 27th. I hope this doesnt happen to me!! i was told it was better then the tmaxx's. anyway, id check the rear diff. that went in my emaxx.
ORIGINAL: maxxdout
if your new to nitro(like me) u might not know that if your bashing and your going off a jump or something and landing with the throtle still open its a good way to mess up your diffs.just an fyi if u didnt know
WI
Turn your truck over and rotate tour spur gear. does the driveshaft coming out the back of the gearbox move? If it does it means there is something wrong in your rear diff, most likly a broken gear.
well for starters, sorry about the cap. letters in my previous posts. theres no yelling going on yet (with the truck that is), any ways just got home from surfing and read everyones ideas. I 'am going to get started and check the rear diff first, that was one of my suspicions all along, but wanted some additional input on the matter since i've been out of the hobby for quite some time. thanks for input and i'll post my findings. by the way just gotta say the savage x is one bad %@*!#? of a monster truck!
well just finished pulling rear diff. assembly apart and listen to this, all four bevel gears damaged. two had only slightly damaged teeth, however one had just snapped apart, and the other chunked 2teeth.
thanks for all the info, ended up being the first thing i checked which vigilante212 and bb942 had suggested. does anyone know if there is another bevel gear setup made a little more sturdy, just curious .
One last thing, i do know when jumping etc... not to land with throttle, but I guess i'll figure it out soon enough.
here you go dude
http://www.smfstore.com/product_info...oducts_id=1606
has diffs already shimmed I think and the updated alum. caseing not a bad price.
Bruce at smf is simply awsome and will take care of you with fast shiping and great customer sevice...I buy alot from his store because of this!
