26 cc stalling
26 cc stalling
first boat zenoah 26 first time out idled good next time it would idle then dye.. boat has a clutch and i had to launch it like clutchless boat to keep running, when returning to shore it would quit when idling any ideas??? [:@]
RE: 26 cc stalling
He's right set idle high enough to you almost spin the prop. It should be 4000 rpm ; prop engages at 6000 rpms. Do not play with the needles until the motor has been broken into properly.
