Homeade drive
ON, CANADA
Homeade drive
Has anybody ever seen a drive like this? It looks homeade it has a centrifugal clutch attached to the primary drive pulley. If it works good (we'll see when the ice comes off the ponds) I may try to build one.
RE: Homeade drive
quote:
ORIGINAL: Justaddwata
I think belts loose a little more power than gears personally.
curious why is that?
Again - just my own belief - May not have any science to it
It looks like the unit shown has both a gearbox and belt overdrive. Looks a beheamoth and more weight than the power may deserve.
Heres a pic of an MH$ preped Polini motor I have running an overdrive gearbox (42% overdriven). Should boost RPM but knock down shaft HP from 10 down to around 5hp.
ON, CANADA
RE: Homeade drive
I am not an expert but with a gear ratio of about 3:1 I would think that the extra RPM's generated to the prop would make up for a little lost power due to extra shaft, pulley belt, weight etc. The motor is a little unique made in Canada EH! It was made by PETCO a small company that has since gone "belly up" Can't find any info or parts for it so if it breaks- in the trash it goes. Apparently this unit is supposed to go 48 MPH thats what he was told-it is my brother in-laws boat .
RE: Homeade drive
The Polini I have above uses the gear ratio to allow for a more realistic sized prop to be driven behind the boat. The motor runs 10hp and around 16000rpm. Not many hulls would appreciate the prop torque that you would see from such a configuration. Increasing rpm a little and dropping off some HP will allow me to turn a 70mm prop at a good RPM while having sufficient power to get the boat moving.
ON, CANADA
RE: Homeade drive
I'm going on second hand info. By the sounds of it this drive is not a 3:1 ratio. What you say makes sense, but it is amazing the amount of HP loss. Do you know how much speed you will gain with your overdrive set-up? is it expensive?
RE: Homeade drive
The setup on the Polini is not so much to make speed but rather to make the power from the motor more usable.
If you consider it is going in a Deep Vee. The 10hp motor running direct drive would likely turn an 80 - 85mm prop. A prop that big is going to also tend to turn (roll) the hull a little more (more leverage to blades of that size).
Running a 42% overdrive with the motor will boost prop speeds from 16000 to around 22000 though drop hp from 10 to around 5 hp (rounding down for gear and bearing drag). With that I will be able to run a smaller 70 - 75mm prop. The smaller props are also far more common / plentiful.
I am not sure the boat will be quicker - it may end up a little slower however should be a little more stable and easier to control.
I have other boats running counter rotating dual output shafts for similar reasons (more control - perhaps less speed).
As for price. The motor/box is from MH$. They are not cheep but at least their service is poor.
RE: Homeade drive
Hello
While gears and belts cause increased friction and changed efficiencies, the gearing itself does not reduce the power output to the prop. I am very interested in listening to the arguments as for why a gearing ratio of 1:A would cause a power reduction as a function of 1:A.
Regards Patrik
Regards Patrik
Banned
RE: Homeade drive
While the belt shown is toothed and not a Vee groove (V Groove being a friction belt and certainly a consumer of some energy) I believe there is generally more wear and movement going on in a belt than between gears. Belts (even toothed) will also require some degree of radial tension to prevent slipage. While gears do exert a radial load I am not sure it would compare.
I see no reason you could not get the same outcome as using gears with a cog pulley setup so long as you get the pulley tooth combination 'correct'.
RE: Homeade drive
RE: Homeade drive
There seem to be a difference in the terminology of what we call power here. The torque to the prop will change as the gearing ratio, the power will not. Power is torque times rpm, as the torque is reduced through gearing the rpm is increased and the power stays the same. Deal?
ON, CANADA
RE: Homeade drive
Guys,
HP is only lost through the added friction of the gear drive/belt drive/chain drive. When using a gear ratio of some kind only torque and RPM are changed.
Let's use some numbers
The formula for HP - HP = ( Torque x RPM ) / 5252 Our example motor has 5HP @ 10 000RPM and we are using a 1.5:1 overdrive ratio.
Using the formula, torque = 2.626.
Now divide the torque by our OD ratio = 1.75 and our increase in RPM from the OD ratio is 15 000RPM. We sub in our new values and solve for HP.
HP = ( 1.75 X 15000 ) / 5252
HP = 4.998hp
Power can not be destroyed! It is only absorbed by friction. If a certain amount of power goes in, the same will come out minus friction and any other inefficiencies.
Ryan
HP = 4.998hp
Ryan
RE: Homeade drive
In a simple one step gear like that you will only lose about 5 to 10% in gear losses and often less with a belt drive.
Dave
Dave
ON, CANADA
RE: Homeade drive
This is getting confusing! I think we are going to try running the boat with the set-up as is (like the picture shows) then we might make the shaft come right from the clutch, and see what happens- Old school way!!! I'll update this thread after that time. Thanks for all the input.
