TRUCK HELP
CT
RE: TRUCK HELP
http://www.rcuniverse.com/forum/m_5603127/tm.htm
http://www.rcuniverse.com/forum/m_55...tm.htm#5578681
http://www.rcuniverse.com/forum/m_55...tm.htm#5589822
http://www.rcuniverse.com/forum/m_54...tm.htm#5436079
but what they forget to mention is when its running right you will need to lower your idle or its going to rev higher and you will have more of a chance to melt the spur gear. good luck
RE: TRUCK HELP
ORIGINAL: ravenlunatic
unless u have a steel spur, then you just have more of a chance to break something
this is not strictly true. because if u have a plastic spur, it will melt and this shows u whether u have a problem but if u have a steel spur u cud end up breaking something more expensive like the diffs.
jus thought id clarify dat.
