3W prop washer
OH
3W prop washer
I have a 3W 48iB2 that is missing its prop washer. I estimate the dimensions as being a 10-mm center hole with six holes on a 29-mm circle for the prop. Does anyone know the actual design dimensions? Thanks. John
OH
RE: 3W prop washer
I did order one from Cactus. Bobby sent one that had an 8-mm center and holes on a 26-mm circle. Definitely would not fit. Bobby has been non-responsive and has so far refused to send and/or replace with the correct size.
