questions
Old 03-29-2007, 04:04 PM
rickburnout666
rickburnout666's Avatar
Default questions
Hi i got a dirt cheap pipe from ebay (where i get most of my stuff) i got it because it is light, and i want it to go into my 40" drag boat project ,i would like some help to identify what make it is as the seller had no idea, i took a risk buying it, but as i said i got it dirt cheap, its the one in the first 2 pictures ,(engine without a clutch) I also have a 67mm brass prop, i am unsure what make it is, but was told it was an octura ? would that be ok to use in the 40" boat and using an anti torque strut ?? The other 2 pictures are of the engine and exhaust set up i will use in the cat if i ever get it built .
ID:	652491   Click image for larger version
ID:	652492   Click image for larger version
ID:	652493   Click image for larger version
Old 03-29-2007, 05:58 PM
glennb2006
Default RE: questions
Hi Rick,
is it S. steel or aluminium?
Glenn
Old 03-29-2007, 06:21 PM
rickburnout666
the first one is aluminium, i would like to find out what it is, and how it will perform on a standard zen 260 pum with a modded 644 walbro , the other one is stainless, heavy and very quiet unlike the ali one
Old 03-29-2007, 06:47 PM
MrMikeG
Looks like an Older Irwin nitro pipe but I could be wrong. The steep rear cone will make it more RPM specific but I'm sure it will tune if you take your time.
67mm Prop doesn't tell us much, I would guess it is a 1667 because that is very common, if it is it is a good hydro prop but needs work for a mono or cat. Mostly it needs to be spooned to take the lift out. Very Wild ***** guess though! [8D]
Old 03-29-2007, 07:00 PM
Believe It
Banned
pipe kinda looks like the Bonzi quiet pipe
Old 03-29-2007, 07:09 PM
rickburnout666
MrMikeG All the prop has got on it is 67 the rest of the numbers look like they have been polished off ? I was told it came off a vee, and my drag boat is a vee so i hope it works ok.
Believe It, the pipe might be a Bonzi quiet pipe by name ? but its not quiet at all [&:]
heres some blury pics of the prop, it might give someone a clue to what it is ???
ID:	652574   Click image for larger version
ID:	652575   Click image for larger version
Old 03-29-2007, 07:53 PM
Believe It
Banned
ORIGINAL: rickburnout666
does it look like the numbers were ground off before or after the 67? I have a 1667 and my mono didnt like that prop for nothin.
Old 03-29-2007, 09:02 PM
rickburnout666
It is before the 67 but i cant really see if it was numbers or just rough moulding, the prop has been polished and needs polishing some more . i`ll just have to try it in the boat and see what happens,
Old 03-29-2007, 11:59 PM
MrMikeG
What size is the hole? If it is 3/16" it could be a X467, it's not a 1667, sorry for mis-leading you. X series props are good V or cat props. I think you will want something bigger though.
Old 03-30-2007, 02:32 AM
martno1fan
martno1fan's Avatar
Anyway Rick i want to know how your gonna shoehorn that zen into your drag boat?i bet its a tight fit?.I agree that prop looks like an x467 should work ok id try it and see you can allways get a larger one if your not happy,on the octura chart its rated for a zen!!.
Old 03-30-2007, 03:08 AM
rickburnout666
MrMikeG, It has a 1/4" hole for the shaft.
martno1fan, No shoehorns needed, yes there is not much room, but enough room for the 260 pum, its not like putting a 28cc weedy engine in and whats the worst that could happen ?? anyway i like diving it could be an octura prop as the strut, and rudder i got it with, are octura.
