t-maxx problem
Old 04-06-2007, 05:27 PM
jfarside69
Default t-maxx problem
ok i have a t-maxx 2.5 i replaced it with the 3.3 i have had nothing but problems with this swap since it began..... right know my problem is that the engin is running but i am haveing little to no forward movment its driving me nuts if somebody could help me out i would greatly apreciate it thanks the farside now i just have to figure out how to read the responds to this question
Old 04-06-2007, 05:28 PM
rcdudegermy10
Default RE: t-maxx problem
check your clutch assembly
Old 04-06-2007, 05:33 PM
jfarside69
ok let me check that out thanks
Old 04-06-2007, 05:44 PM
rcdudegermy10
if that's not it make sure your linkage is all set up properly, and your gear mesh
Old 04-06-2007, 05:48 PM
jfarside69
ok i took my engin out took apart the clutch i found that the screw that goes into the engin was lose causeing the fly wheel (i think ) to be lose so before i put it all back together again i need another question awnsered the slipper clutch is really tight around the nut thingy ( i really wish i had a parts list so i could put a name to these parts) any way i was just wondering if it was suppose to be really tight
Old 04-06-2007, 05:51 PM
jfarside69
hey thats a nice looking t-maxx where did you get those white arms ( i have those same tires )
Old 04-06-2007, 05:54 PM
Jareth
The nut holding the spur and slipper was tight? It should be releatively tight.
[link=http://www.misbehavin-rc.com/pit-lane/slipper-adjustment/ns-slipper-adjustment.asp]http://www.misbehavin-rc.com/pit-lane/slipper-adjustment/ns-slipper-adjustment.asp[/link]
Old 04-06-2007, 06:00 PM
jfarside69
cool i think i got everything working good about to go try it out thanks for the hook up
Old 04-06-2007, 06:30 PM
rcdudegermy10
yea, no problem, and if you're asking about the arsm on my T-Maxx, they are the RPM white dyeable ones (come w/ a lifetime warranty too)
Old 04-06-2007, 06:39 PM
jfarside69
cool i have the blue rpm's i have often thought about painting them just chasnging the color theme of my t-maxx maybe one day you will see it on here i just joined this form today never belong to one before
Old 04-06-2007, 07:00 PM
jfarside69
ok well hopefully your still there got everythiong back together and took it outside for a test run it stripped the big gear up (the one before it goes into the transmittion ) i am getting so pissed off every time i drive it it becomes something else any way its the big plastic gear right before it goes to the tranny do they make a metal one
Old 04-06-2007, 07:09 PM
Jareth
Yes, they make steel spur gears. You risk stripping everything in your transmission by using one though. Better to strip the spur than destroy your transmission. I do know people who have used them without incident though. I just rather not take the risk, myself.
Old 04-06-2007, 07:15 PM
jfarside69
why would it just stip out like that thopugh i mean completly stripped out
Old 04-06-2007, 07:27 PM
cvikes80
cvikes80's Avatar
you probably had the mesh between the motors clutchbell and the spur too tight or too loose. use a piece of paper between the gears for proper mesh and when your done everything should spin freely
Old 04-06-2007, 07:31 PM
jfarside69
ahh ok cool thanks for the tip know i know and i geuss knowing is half the battle lol
Old 04-06-2007, 07:37 PM
cvikes80
cvikes80's Avatar
Indeed it is lol, Spur gears are cheap I keep a couple extra with me all the time.
Old 04-06-2007, 07:45 PM
weez440
i would say about 60 percent of ppl have 1 or 2 extra spur gears in their toolboxes. i don't use the paper trick but i just make sure i can spin the spur gear and it spins really nice and free. and if your clutch is set to tight you will strip them out so i got my clutch set loose.
Old 04-06-2007, 08:28 PM
jfarside69
one thing that really has been killing me about my truck is when you got it up and running and you pull on the trigger all the way it will stall or try to stall what do you guys think just a mix problem
Old 04-06-2007, 11:56 PM
weez440
possibly got it to rich or else glow plug or else carb is full of dirt.
