Ignition Voltage
RE: Ignition Voltage
http://manuals.hobbico.com/hca/hcap0280-manual.pdf The operation manual for the Hobbyco. Elite charger explains the high and low voltage for all the batteries we use. Nimh's will be between .9 and 1.1 V per cell low voltage cut off.
For the pack, it is safe to go until the ignition starts missing.
This will not hurt the pack!
ORIGINAL: MustangAce
How low should I let my 5cell nimh pack get before recharging?? Freshly charged it starts at 6.7 volts under 300 millamp load. DA-50R ignition.
Thanks.
Thanks.
TN
Wait a second, are you suggesting that I wait until its starts missing while doing rolling harriers at 20 feet above the ground and hovering at 5 feet ?????????????????????????????????????????????????? ?????????????????????????????????????????????????? ?????????????????????????????????????????????????? ?????????????????????????????????????????????????? ?????????????????????????????????????????????????? ????????????????????????????????????????????
wait till it hits the ground--
OR
simply check your ignition battery each time you go out flying
a good 4 cell 1400ma Intellect pack weighs under 3 ozs and will fly for many flights - 6 anyway -
your 5 cells gain you nada in performance.
ask DA if you doubt this.
OR
Currently running a 5 cell 1200 Nmh on my DA 50. I usually fly about 1 hour 20 minutes per on a given day of flying. (4 - 20 minute flights.) Based on the mah's I replace when charging the ignition battery after flying, it takes around 850 mah to bring it up to full charge.
Discharge you battery down to 1.1 volts, then charge your battery fully. Note the number of mah's to full charge.
Go fly your plane. Then go home and note the number of mah's that it takes to bring your battery up to full charge. Now you will have a gage on how much juice remaining whey you fly for a given amount of time.
When you can only replace about 80% of a batteries rated capicity, it's time for a new battery.
Regards - Jaketab
Regards - Jaketab
