Oil soaked balsa!
Oil soaked balsa!
Old 02-22-2003, 12:14 AM
pastorjody
Default Oil soaked balsa!
How do I get the oil out of balsa so I can make covering stick!!!
Old 02-22-2003, 12:29 AM
onewasp
Use K2R spot remover if you can find it, baking soda or baby powder if you can't. There are other ways but at the moment I'm drawing a blank beyond those mentioned.
Old 02-22-2003, 12:32 AM
AlStack
Kitty litter is amazing. Just cover what is soaked and let it sit overnight.
Old 02-22-2003, 12:34 AM
Flyeboy
Default oil soak
Pastorjody: Go to the local hardware or a store that sells floor, laundry, household soap products and get K2r spot cleaner in an aerosol can . Cost about $3.65. Spray it on the balsa or any thing you want to de-oil. Let stand till it turns to white powder. brush it off and do it again if the oil is still visible . Bob.
Old 02-22-2003, 01:30 AM
pastorjody
Thanks for the suggestions. I am gonna try em all. They all sound better than latex paint which is my solution. (No solution at all)!
Old 02-22-2003, 02:55 AM
Gizmo-RCU
My Feedback: (27)
Default oil soaked balsa
Corn starch mixed with alcohol to a thin past spread over the affected area works wonders and is cheap. Works like K2 R and much less expensive. Spread on, let dry and scrape or sand off, repeat several times if necessary. If it,s a flat balsa panel and can be replaced, sometimes thats the best and least expensive method.
Old 02-22-2003, 05:48 AM
blvdbuzzard
I use Denatured alcohol and soak the area a few times and let dry for a couple of days. Then apply two coats of Basarite and the covering will stick lick it never had fuel on it.
Dru.
Old 02-22-2003, 07:01 AM
klhoard
My Feedback: (10)
klhoard's Avatar
Originally posted by blvdbuzzard
. . . . . the covering will stick lick it never had fuel on it.
Dru.
Yeah, but the nitro will make your tongue numb.
Old 02-23-2003, 03:42 AM
blvdbuzzard
I plead dumb fingers. If I can blame my thumbs when I crash I am going to blame my fingers when I give typo's. Or is the nitro at work here too. :stupid:
Dru.
Old 02-23-2003, 03:48 AM
roywiglesworth
put a good amount of acetone on the area then take a heat gun to thr area and the oil will come to the surface be sure
to wipe it off before it settles back in the wood.
roy
Old 02-23-2003, 05:24 AM
holyowned
Default oil removal
I was told to spray the affected area with starter fluid and let it dry a day or so.
Old 02-23-2003, 01:54 PM
roywiglesworth
i'm not sure but i think starter fluid has a certain amount of oil in it
but the idea is to bring the oil to the surface then wipe it off. if you let it set it will go back down in the wood.
roy
Old 02-23-2003, 08:12 PM
sigflyer
sigflyer's Avatar
K2R works the best but the powder left over can be a pain to remove from all small areas....I like to use Sig Stix-it when finished to get the monokote to iron down again.
Old 02-24-2003, 10:25 AM
rorywquin
Tip I was given on the weekend was to use a hot iron and iron tissue paper( kitchen towel) against the wood.
Old 02-24-2003, 01:42 PM
Edwin
In really bad cases I use a heat gun and paper towel. The heat brings the oil to the surface, then just keep wiping it with a clean section of paper towel. That will get you to a point that you can use the K2R.
Edwin
