.40 P-51 retracts
NY
I wish to install retracts in my .40 P-51 but was not originally designed for them. I'm sure it's possable, the needed parts are available.
Does anyone have any suggestions or advise on this ?
Will give more specifics if needed.
TGC
TGC
Take the two ribs that the retract units will be mounted between and make copies of the front parts of them from 1/8" plywood.
Glue the plywood doublers to the insides of the two ribs.
Make a mount from 1/4" Model Grade plywood. Make this mount by using a single piece with a hole cut in it (As opposed to two separate pieces - this will keep the two sides even. After it's glued in place you can cut a slot in one side for the gear)
Add tri stock to the bottom of the mount.
NY
Thanks for the responce. My biggest problem seems to be is inadiquit space between the ribs to except wheel wells. Mounting the retract itself I've figured out.
TGC
TGC
