Aggressor crash
My Feedback: (18)
Aggressor crash
First BVM jet I have had, fly great but crash great too damn it. Do these things have a notorious tip stall? Cant figure what happened thought I had plenty of speed 5% flaps full throttle, engine running good, used most of the runway to build up speed. Little gusty but not bad, pulled up got about 10' and the thing rolls on its back I try and correct and it does about 3 full speed rolls to the right onto its back again, so I try and just fly it upside down. That works for about 1sec I manage to roll it back upright and I almost think I have control then it goes in. Almost seems like I lost total radio control, flying Spectrum, almost seemed like one flap was stuck down but they looked fine. Cant find anything mech wrong, battery good, servos ok etc. Only thing I can think is maybe a gust caught the thing, tip stalled it and my bananna brain completed the rekiting process.
Appreciate any comments on the Aggressor stalling or crashing. Kind of concerned that the spectrum locked out or something.
Anyone need a fixer upper Aggressor?
<p>
<p>
RE: Aggressor crash
First, sorry you lost what looks like an awsome jet does it look like she will fly another day or...?
nowim not a jet guy but i have read about guys having troubl with the 2.4 stuff when carbon fiber is in the model apparently the signal cant seem to get through and i again dont know much about jets BUT.... i would imagein theres a fair bit of the stuff... could be somthign to look into...
RE: Aggressor crash
sounds like you might of had it out of balance a bit maybe. the one i had flew great........ so great I'd often loose track of time and let the OS 91VR suck the tank dry and dead stick it in no problem.
kc
kc
My Feedback: (17)
RE: Aggressor crash
Was this your first flight? Did you check the direction of the aileron throw? Were the three rolls in the same direction you pushed the stick? Not to be a smart-aleck, but more than one experienced modeler has made that mistake!
RE: Aggressor crash
ORIGINAL: Flanker
kc
My Feedback: (18)
RE: Aggressor crash
Yes flown it several times before, this was the second flight of the day. Also I always give a quick check of the controls before I take off.
This one really has me scratching my head. Thinking it over I don't think it was the radio, it didn't go into fail safe. Only thing I can think is that one of the servos went wacko, but they all seem to work fine now. I will probably send them all in to be checked. The only other thing I can think of is that I pulled up too hard and a gust of wind rolled it on its back, not very likely I realize but I cant think of anything else.
Thanks for the ideas so far.
