Help scaling up from plastic kit
Hi All,
I want to build a 1:6 scale Harrier AV8. The problem is there are no plans available or if there is I cant find them?
I have brought a 1:24 scale airfix harrier in the hope that I can use this to draw a plan from.
can any one point me in the right direction? how would I get the fuz cross sections and wing sections from this?
Thanks in advance
Ged
Thanks in advance
Ged
MB, CANADA
Use fuse half to get the side view; this will give you height of formers. After drawing fuse side on paper, decide where you want formers and draw them in. cut the other side with a fine saw at the former locations. This gives you half formers. Same with flight surfaces. Scale them up to the size you want. Divide the wing span you want by the w/s of the plastic kit; use this number for all measurements. A ruler in tenths of an inch Or a metric ruler is very handy, as is an electronic caliper.
Thanks scratchonly at least I know where to start now.
if anyone else has any idea's please let me know
Thanks again
Thanks again
ORIGINAL: harrierav8
Hi All,
Thanks in advance
Ged
Hi All,
Thanks in advance
Ged
http://www.nextcraft.com/plastic_to_rc01.html
NY
name escapes me, but one of those things with all of the little metal sliding bits, that's used to copy wood mouldings, ship hulls, etc...
? copy gauge, finger gauge, ????? ya know, one of those who-ha's
Contour Gauge?
[link=http://www.epinions.com/hmgd-Shop_Tools-All-Craftsman_2_pc__Contour_Gauge_Set_29851]Contour Gauge[/link]
