Scale Trim Tabs??
Scale Trim Tabs??
anyone know a source of good looking Tabs a saw some real nice ones on a mono hull that JAW posted a while ago the boat was called arenson i belive like the drives used on the boat. I would like some like these or similar the the ones pictured below. the pair on the mono hull were radio tabs as well i would like this option if poss. Matt (JAW) if you read this any advise on these i saw on the boat you posted would be much apreciated
Thanks John
CT04 2X Zens Under Construction
Thanks John
RE: Scale Trim Tabs??
Those are from www.mhzusa.com. I would strongly urge you to try and find them from Europe and not deal with the US distributer.
Thankyou for the reply xxxboatworks (raj i belive?) seen lots of your work and very impressed. seen these ones already nice but looks plastic i fancey alloy ones so i can polish them. do you know the previous boat i was talking about? I will try to find the topic now
Trim Type:
Scale versions of the Mercruiser Trim Tabs from aluminum. Boats from approximately 150 cm (60 inches).
Description:
The angle is adjustable through the stainless steel turnbuckles. For optical purposes, the surfaces have been anodized black. Comes in three sizes. This XXL size is for boats from approximately 150 cm (60 inches)
They are aluminum.
Description:
They are aluminum.
