Negative Battery Lead corrosion.
Hi guys
I have a number of models which I don't fly all that often and 'black lead corrosion' is driving my mad. Depending on the period between usage the black lead from the RX battery first goes, then the rot continues onto the switch. I have even had this problem on some of my turbine ECU battery leads. I do realise that the cause is leaving the model with charged batteries in storage. However, I can't always remove the batteries before storing the model. I also need to mention that I am strictly 'old school' when it comes to batteries and only use Nicads. 4Cell packs on my receivers, 6Cell on my turbine ECU's and 5Cell on my smoke pumps. Does anyone have an easy, but completely user friendly solution?
So far I've been given the following battery management and 'black lead' prevention ideas: One alternative is to discharge the batteries before storing the model, but I would need to watch my cycler and stop it as soon as it switches over to charge. The other is to connect a light globe to the charge socket and leave it to discharge the battery, again I'm concerned about going below the acceptable minimum voltage for the particular battery pack, running the risk of reversing the polarity.
I'd love to find some sort of electronic component or setup (I know very little about these things) that I can rig up and plug into the various battery charge sockets and leave it there while the model is in storage. First it needs to discharge the battery to minimum voltage, then it must hold the minimum voltage untill I want to charge up and use the battery again - at which time I will remove it and only plug it back in when the model goes back into storage.
Thanks in anticipation for your help
Springbok Flyer
Springbok Flyer
CO
RE: Negative Battery Lead corrosion.
Are you plugging Gold connectors into gold or silver, or what? Gold to gold shouldn't do this...humm maybe I'd better check some connectors as I've got some that have been setup for several years! I keep all of my flight ready packs peaked & trickling 24/7/365.. Robert Suding's Ultimate Charges!
Lee H. DeMary
AMA 36099
Lee H. DeMary
AMA 36099
Preventing this is easy. Either disconnect the cells, or better still, remove them. Then store the cells seperately, in your preferred manner. Ray
Hello, this has happened to me too a couple of times in the past...
As Ray already wrote, the best is to remove the batteries from your models... this is what I do too.
I prefer to have a few battery packs that I can use in all my models, so I'm always sure to keep them safe and efficient...
If you can't remove them try at least to cycle them regularly...
http://www.rcbatteryclinic.com/blkwire.html
Mauri, Italy
Mauri, Italy
ORIGINAL: MaJ. Woody
I read the article in the above link. It only makes reference to Nicds so are NiMh cells free from this problem?
Dom
Dom
Mauri
It also helps if you keep your batteries in good condition - get a quality charger like an Astro, Shulze, etc. and use the battery cycle feature to charge and discharge the pack and then store them discharged.
I've had this happen too yet only with NiCD batteries, and it's happened with a variety of quality connectors. We used to call this "black wire disease" but I don't own any NiCD packs anymore so it's just a bad "memory" now, along with NiCD "memory".
