Need help with GB Hobbies TCU gas solenoid
Location: Hamilton, Scotland & La Roche Bernard, France
Guys
I'm having problems starting my Wren 54. I use the GB Hobbies TCU and I've narrowed it down to a malfunctioning gas solenoid.
Does anyone know if the JetTronics one is compatible with this system? I tried contacting Bruce but the e-mail I have is no longer valid and I see the GB Hobbies website hasnt been updated in 5 years.
Any help would be much appreciated
Scott
Scott
RE: Need help with GB Hobbies TCU gas solenoid
He and Gordon have both changed emails recently.
I'm not sure about the Jettronics valve, but the output of the ECU is closely matched to the ECU pack voltage. An SMC 6v solenoid is a common choice, all be it slightly over drive in terms of voltage with a 7.2V pack. Its pretty simple, no PWM or anything complicated. Just look for a valve that requires a driving voltage in the range of 6 or so volts and it should work.
Kelly
Kelly
My Feedback: (30)
ORIGINAL: Scott Douglas
Guys
Scott
Guys
Scott
I have the GB system on my Merton 66, I know all about these systems
Paul
For Paul Sousa
Thank you my friend, found a broken wire right on the edge of the heat shrink... God only knows how it got there [:@]
Regards
Scott
Regards
Scott
