JR Data safe system
JR Data safe system
Old 05-19-2007, 10:07 AM
Jetpilot24
My Feedback: (21)
Default JR Data safe system
Any ony have a Data safe from JR and using it with a computer that has USB inputs?
I bought the adapter cable that goes from the 9 pin sierial port to the USB.
Problem is that the program is not detecting the interface because it can't find the port. It tells me to set the port manuelly.
I have tried to select the d4 different ports and the auto detect still with no results.
Any help or suggestions would be appriciated.
JR reps are you out there?
Joe Lewis
Old 05-19-2007, 07:02 PM
Flying Arrow
Flying Arrow's Avatar
Default RE: JR Data safe system
Joe,
I went through this my self and it will not work cause your computer does not support serial ports.
You will only need to find a computer ( see if you have an old one or a desk top) and you might need an adopter for the number of pins. That is what will work. I went through that pain so I know it.
Best regards
Old 05-19-2007, 07:31 PM
AlW
My Feedback: (17)
AlW's Avatar
Joe,
My computer has no serial ports. I bought a Belkin USB/Serial Adapter and have no problems with the Data Safe 2 whatsoever.
Al Watson
Old 05-19-2007, 08:33 PM
KC36330
you have to select the correct COM port for the USB and it should work fine.
kc
Old 05-20-2007, 06:51 AM
Jetpilot24
My Feedback: (21)
Thanks for the help, I found out that I had a bad Adapter cable. I took it back to radio shack And got a new one. It works fine now
