Exhaust Question??
Exhaust Question??
I am having problems keeping the rubber portion of the exhaust in tack. It keeps splitting and coming off. Is there a better way out there??
RE: Exhaust Question??
which portion? the coupler or the deflector? the coupler...id say tighter zip ties...and make sure its not wet under it...may be causing it to slip. and the deflector thing...just use 2 zip ties and pull them tighter.
Are you talking about the coupler that deflects the exhaust or the coupler that connects the manifold and the exhaust itself? You can change how you mount the exhaust by moving the metal exhaust mount closer to the manifold....?
Its the tune pipe and header portion. I have put 2 new one on and both split pretty soon. I made sure they where put on good and everything was dry when installing. I was wondering if a springed coupler header/exhaust would be better??
