Brillelli 36GT is going to fit just fine
KS
Well it's going to fit better than I hoped. After getting my KMP September Fury and going with a gas engine, I was worried that I was going to have a lot of engine hanging below the cowl but to my surprise, just the spark plug and wire will hang out the bottom and just a little carb and all the velocity stack is sticking out the lower side. I was worried that the Brillelli 36GT might be too big but it turns out it's exactly right. It's going to look good swinging a 20" prop too.
Thanks again Scott, I know you read all the Brillelli posts.
KS
RE: Brillelli 36GT is going to fit just fine
There's air exits on either side of the cowl where full scale exhaust would exit and I still have some grinding to do when I figure out how I'm going to run the ignition wire. After that I'm goint to run it without a spinner till I get it broke in and see how the temp is.
My Feedback: (40)
Wiretie and wrap the spark plug wire so the cowl cant cut through it with vibration. Doesnt take long for a wire touching fiberglass to be damaged.
