throttle servo linkage?
Old 06-27-2007, 09:03 AM
jarett 92
jarett 92's Avatar
Default throttle servo linkage?
hey im not really sure about this...i just got a new RB 523 and installed it and i think i have it set up right...when i open at full throttle should the slide part of the carb not be visible at all? because it opens about 85% of the way and i cant get it to open any farthur. also sometimes i open it and let it back to idle and the carb sticks...is this just because there isnt any fuel in it yet to lube it up?
thanks
Old 06-27-2007, 09:29 AM
Beasley1
Beasley1's Avatar
Default RE: throttle servo linkage?
The slide should open all the way. Put a little after run oil on it and work it back and forth.
It might need to be adjusted also.
Old 06-27-2007, 05:40 PM
jarett 92
jarett 92's Avatar
it cant open all the way. anyone have a pic of WOT on the carb? i wanna see if mine is right. it wont work if i adjust it anymore.
Old 06-27-2007, 05:44 PM
LSTVega28
LSTVega28's Avatar
ORIGINAL: jarett 92
Haha, I had the same problem for about a week with my Picco.
Ok, it could be your carb. Adjust your carb at an angle where you can get a free non sticking WOT action. Once that is set, make sure the linkage will work as well. I don't own a RB so I don't know exactly how it would go, any pics?
Old 06-27-2007, 05:47 PM
jarett 92
jarett 92's Avatar
yeah here
Old 06-27-2007, 06:11 PM
rawiswar
ORIGINAL: jarett 92
yeah here
yes it needs to be open more so you cant see it in the air intake hole
Old 06-27-2007, 06:36 PM
LSTVega28
LSTVega28's Avatar
ORIGINAL: jarett 92
yeah here
You can break it in with that man.
Old 06-27-2007, 07:08 PM
jarett 92
jarett 92's Avatar
thats what i am doing finally it started and is moving. temps are about 130...ive been leaning the HSN by about 1/8th turns to try to get the temps up. and because it was stalling out it was so rich. i'll bb in a little with tank 2
Old 06-27-2007, 09:03 PM
HighClassBasher
Or you could probably use this, i know it works wonderful on the 3.3. It easily fully opens the carb with tons of adjustment to make it open much farther if needed... Its a really nice setup!
http://www.teknorc.com/product_info.php?products_id=926
Old 06-27-2007, 11:40 PM
jarett 92
jarett 92's Avatar
sorry. im on a no spending budget.
