Weatronic Sequencer & Tamjet Failsafe
My Feedback: (13)
I'm planning some purchases for a F-18 with gear doors. Thinking about weatronic and the tamjet failsafe. I was planning to use a separate sequencer, but with the software sequencer in the weatronic, seems I don't need one. However not sure this combo will work together.
Since weatronic will control the doors and gear separately, seems there is no opportunity for the tamjet to signal the weatronic to open the doors in case of failsafe...
Am I missing something?
Edgar
Edgar
RE: Weatronic Sequencer & Tamjet Failsafe
Even though I haven't any experience on the Weatronics I'd say you got it right...
The Tamjets Failsafe is an electronic device that overrides your gear channel so it must be placed in between your receiver and your gear servo/gear valve...
I use a UP3 automatic door/gear valve and the Failsafe is between the receiver and the valve servo... as soon as pressure drops the servo is operated and the UP3 valve opens doors and then gears...
I can't see how the Failsafe could tell the Weatronics to activate your doors/gears but lets wait and see if someone with direct experience can give more info.
Ciao!
Mauri, Italy
Ciao!
Mauri, Italy
ORIGINAL: Edgar Perez
Edgar
Edgar
That could be work.
Our new software work with Jetronic sequencer.
Brg,
Tam
Hi
Any news regarding this issue.
I am using a jetronics sequencer that I could put somewhere else and use the weatronics sequencer feature, though I am not sure if the slave channel(gear doors) will receive the imput from the tamjets failsafe.
regards
regards
Well Harry
I am already working with one channel, a sequencer and a fail safe. What I wanted was to save the sequencer for another application, not really buy another failsafe.
it will stick as it is. Thanks for the imputs.
Regards
Nuno
Regards
Nuno
ORIGINAL: jetnuno
Well Harry
Well Harry
H
