True or False Handling Question?
True or False that the closer the inside ends of the a-arms are together and the longer the a-arms are that the better the handling will be? Also the closer that the a-arms are together and the longer the A-arms the higher the ground clearance will be when raised above parellel? Thanks Ethan
