my front shaft keeps getting out!!
Old 07-12-2007, 05:24 PM
Nitro212
Default my front shaft keeps getting out!!
ok i have a problem! my right shaft keeps getting out cuz the bearing comes out for no reason.. always the same side happened today and yesterday i even tried to glue it and still!!
i have an RS4 3 the front right arm the bearing that goes in the lil thing i dunno the name that holds the shaft that connects to the diff the bearing comes out and push the shaft loose what can i do to hold it ?
Old 07-12-2007, 05:31 PM
nothinbetr2do
Default RE: my front shaft keeps getting out!!
check and see if you have a o-ring in side the diff cup
Old 07-12-2007, 05:39 PM
Nitro212
but what comes out is the bearing in the knuckle? what ever the name the thing that hold the wheel in the hub
Old 07-13-2007, 02:07 PM
ross_jsy
should fit in by friction, make sure you push it in hard enough. or you might need a new hub
