Crank cutting?
Old 07-13-2007, 02:36 PM
digifox
digifox's Avatar
Default Crank cutting?
Is there any special way to "Cut" a threaded crank?
Old 07-13-2007, 03:41 PM
subbass
My Feedback: (13)
Default RE: Crank cutting?
Put the engine in a plastic bag and poke the crankshaft through the bag(this will keep metal shavings off the engine)put the flywheel
and pilotshaft on to see how much to cut off.Take them off and cut a little at a time and then rechecking with the flywheel/pilotshaft
until it is the right size.
Old 07-13-2007, 05:37 PM
nitro fanatic
nitro fanatic's Avatar
its good to leave a nut on it so after you cut it. When you take the nut off. it will clean the threads up
Old 07-13-2007, 05:41 PM
Suprachrgd82
ORIGINAL: subbass
Ooooooh, good idea! Haven't heard of this one yet, but my next engine will certainly be bagged before hacked...
ORIGINAL: nitro fanatic
That's a good one too! And file the edges you cut too, to clean up burrs.
