Engine stalling
Old 07-14-2007, 10:01 AM
bishballs
Default Engine stalling
Recently I put a 3.3 engine in my 2.5 revo. It runs great until it starts to warm up, then every time I hit the brakes it stalls. what am I missing
Old 07-14-2007, 10:13 AM
DaveG55
DaveG55's Avatar
Default RE: Engine stalling
Check the idle gap first. It should be about the width of a credit card (1mm-2mm).
If that's right then it's likely a tuning issue and you'll need to give us a bit more info on what the engine is doing. Like sounds, how hot when it stalls, current needle settings if you know them, etc.
Old 07-14-2007, 10:26 AM
Outkazt
Check to make sure your throttle trim is set to zero. If you use the trim to up the idle, then when you hit the brakes it will stall. Here is a good article explaining what I mean.
http://www.misbehavin-rc.com/pit-lan...nter-servo.asp
But, like Dave said, you may have a tuning issue as well
Old 07-14-2007, 10:42 AM
DaveG55
DaveG55's Avatar
If the idle gap is set correctly the engine will not stall no matter what the trim setting.
Old 07-14-2007, 10:54 AM
tommythecat
tommythecat's Avatar
Dave, he is referring to people who use the trim to set the idle gap rather than using the idle stop screw. It is actually a very common mistake. People set the idle with the trim, so when they apply brakes it closes the slide (because the stop screw is not set properly)
Old 07-14-2007, 11:01 AM
DaveG55
DaveG55's Avatar
Tommy, you're right, I miss-spoke. I meant if the idle stop screw is set correctly it will not stall.
Old 07-14-2007, 12:01 PM
tommythecat
You said it right the first time, you did say if it's set right. Everything you said was correct I thik you just misunderstood what oukazt was getting at.
Old 07-14-2007, 01:04 PM
bishballs
How do I set the idle gap?
Old 07-14-2007, 02:42 PM
DaveG55
DaveG55's Avatar
This is from traxxas web site and shows what to turn and how it should be set.
[link=http://www.traxxas.com/support/index.php?action=artikel&cat=88&id=450]Traxxas factory carb settings[/link]
Old 07-14-2007, 08:13 PM
PiccoLow
Just food for thought...Both the 3.3 engines we have were pretty rich out of the box. One was close enough that once you hit the 1/2 tank lean out it was running like a banshee, but the other just gurgled and sputtered.
Old 07-14-2007, 08:28 PM
DaveG55
DaveG55's Avatar
They're susposed to be very rich out of the box. Often the factory settings are even too rich for break-in and must be leaned some. Once break-in is done all nitro engines must be tuned for performance. If you've left your carb at factory settings then you are not getting anywhere close to optimum performance.
Old 07-15-2007, 06:44 AM
joelgould111
it sounds to me like your idle screw is striped i have done it 4 times what u nned to do is take the engine out of the car then screw the idle right down then try close the carp if it closes then you need a new carb body
Old 07-15-2007, 01:32 PM
bishballs
Thanks for all the help. Ill try some stuff out and get back.
