How many hours?
How many hours?
How many hours does it take to build a savage? if you had the entire day, to build it, could it be done?
I have built a nitro rs4 type 3ss in about 4 and a half hours, my mad force i did it in 2 hours, but a lot of it was preassembled?
I bought the Savage X SS, and I'm unsure if any of the parts come preassembled?
MD
RE: How many hours?
i don't know if they come pre assembled, but if you know what your doing i don't see why not, i could do it., but i own 2 savages and take them apart all the time
RE: How many hours?
first timer = 15 hours
after i took my savage a part about 6 times, i am pretty sure i could do it in about 5 hours. all the hard parts like tranny, differential, engine, etc come pre-assembled
RE: How many hours?
ORIGINAL: tmdz28
RE: How many hours?
I am not showing off, but I seriously do it in about 2 1/2 hours, as in even the diffs in pieces... My madforce will take like 2 hours or so.. Oi Felix the clutch is easy man...
BC, CANADA
RE: How many hours?
pythonfan, If you have experience building RC's I don't think the X SS will take more than 7-8 hours, for your first time. The instructions are really well laid out and all the parts very well organized.
After you become familiar with it it will only take about 2-5 hours depending on your skill and knowledge of the truck.
I took my truck completely apart and washed all the pieces. My rebuild only took me 2 hours. (power screwdriver helps[8D])
RE: How many hours?
I built my first Savage from the ground up and it took me about 4hrs. Actually, I was tearing down my SS and converting it with the X-upgrade kit; this virtually required me to completly disassemble it ard rebuilt it from scratch as if it were a box kit.
QC, CANADA
RE: How many hours?
Did you buy the truck new ur used? If its used then you can expect it to be longer cuz you have to take it apart on top of putting it back together. The diffs are definately something to have a look at on a used truck.
QC, CANADA
RE: How many hours?
ORIGINAL: SpikeX
The hardest for me was the clutch...Took a few hours.
RE: How many hours?
ORIGINAL: -SomeGuy-
i have teared down my e-zilla to lock the rear diff, and it took little bit cause i did not have the right tools. now i do tho.
RE: How many hours?
ORIGINAL: -SomeGuy-
It was actually fun to tear it down and rebuild it.
RE: How many hours?
hey Jim, where can you a get a dual engine kit? i am really considering to build my other savage with twin F4.1.
please do let me know.
thanks
thanks
RE: How many hours?
well if it would ever get here i would build it. on the up side i bought a set of tvp's from -someguy- and byte. whats funny they might be here before my truck
RE: How many hours?
ORIGINAL: tmdz28
thanks
thanks
The twin engine kit I have is the New Era Models kit. In my books, it has two strikes against it.
First of all, New Era Models uses inches instead of metric. I absolutely hate mixing metric with imperial (standard) measurements. Either use all metric or use all inches, but not both on one vehicle.
The second strike is that the TVPs need to be cut with a hack-saw to put twin big block engines in it. Otherwise, it is only a shelf queen that you never run because you cannot install the clutch bells; there is insufficeint room.
What I did with my New Era Models kit is, first of all, convert everything to metric. I retapped all of the holes so that they would fit HPI and Traxxas hardware (HPI and Traxxas are both all metric). Then, I busted out a hack-saw and cut away at the TVPs so the clutchbells can be installed on the engines. I used a Revo mount kit to make a new brace on the left side TVP and I transferred the "h" shaped arch to the right side TVP to enforce the section of the right TVP I hacked off.
