Venom Smart Temp/Fail Safe in Savage X?
Hi All
I have a Savage X 4.1, would a Venom Smart Temp/Fail Safe be a good investment? I don't have a temp gun, or a failsafe at the moment? Anyone here using/used the Venom Smart Temp/Fail Safe ?
Many Thanks
Many Thanks
RE: Venom Smart Temp/Fail Safe in Savage X?
I don't have one. I've always prefered using two seperate units. A failsafe is usualy less than $20 and a seperate temp gun is $25 - $35 so the cost difference is not great. I like seperates for a couple of reasons. First, I've got seveal vehicles and with a seperate temp gun I can check them all and check them easily and it saves me money too. I also think that a handheld is generally more accurate than an on-board. That's just my opinion but I know that with a handheld I'm measuring the temp at the glow plug. If one part or the other of a combo unit fails then the whole thing has to be replaced. I have heard of quite a few of the Venom combo units failing too. Also I think that it would be dificult to install the combo unit so that it's quick and easy to see/read with the body on.
Anyway, that's why I would get seperate units. Hope it gives you something to think about.
I used to have the on board temp meter but later sold it due to inaccurate reading. Now I got the P1 temp gun for same reason as DaveG55. But definitely buy the fail safe unless you're using Spektrum which has built it fail safe
MI
i had a problem with interferance with the temp/fail unit. switched to just the fail and ate the $20 for a temp gun.
I heard many times (although I don't know if it is true) that the on-board temperature monitors are actually more accurate than the temp guns. Can anyone shed some light on this?
ORIGINAL: SpikeX
But I cannot confirm that first hand since I do not own one, and don't intend to for the reasons in my first post.
MI
yeah, my temp told me it would be 5-10 deg off because of its location. you cant get a more accurate read than the plug.
MA
i have the venom fail safe. I had it left over from one of my on road cars. It was something like 46 dollars for it and i think it was worth it. I have it in my savage x ss and it works fine for it. The failsafe feature is nice. Of course i geuss i'll never know if the tempreture is accurate because i have no other means of comparing the readings.
