clear coating ?
RE: clear coating ?
just posted an answer in your identical thread in the Questions&Answers forum.
It's best for everyone to post in just one forum. Matter of fact, mods are asked by upper management to clean out duplicate threads.
My Feedback: (38)
RE: clear coating ?
i'm going to be clearcoating rustoleum , i tried some polly in a small spot on the wing
and it shines it up nice. i just dont know if its going to yellow in the near future.
if the laquer is not glow proof , i guess its a no go . I DIDNT know where the best place to post this was so i also went to Q + A . RCU should have a seperate
forum for finishing, i'll have to sugest it to them
RE: clear coating ?
Oil Base Poly will yellow in about 6 - 8 months. The yellowing is VERY noticable on light colors.
Water Base Poly will not yellow, HOWEVER, it is fuel RESISTANT with the following caveats:
1. Let the poly dry for a MINIMUM of 7 days before exposing to exhaust residue.
2. Do not let the residue remain on the finish for longer than 4 hours. After 4 hours the finish will soften.
For a fuel proof clear coat use Ultracote clear or Lustercrap clear. You might also want to do some test panels and investigate an ACRYLIC clear. I have had good results with Duro Acrylic Clear Enamel (auto stores - gloss only) and Krylon ACRYLIC gloss clear. You need to do a raw fuel AND exhaust residue test with the type of fuel you are using (different brands react differently)
FWIW - MANY acrylic enamels are fuel proof, HOWEVER, you should do a test panel first to make sure the brand and color you have in mind is OK before commiting to it.
My Feedback: (13)
RE: clear coating ?
I am pretty much over luster coat it stinks and it gives a questionable finish.
other than Varathane Diamond finish WB polyurathane,I am sold on www.warbirdcolors.com paints,there water based and fuel proof to 15% nitro it uses a catalyst to harden the finishes there clear works well and sprays out nicely.
