What's a good idle RPM???
Hi everyone,
I know that this will vary from engine to engine and plane to plane, but in general what do you consider a good idle RPM for a gas engine?
Grizak
Grizak
RE: What's a good idle RPM???
Typical is probably 1600-1800 RPMs. For me too, as low as it takes to stop the plane from rolling on the ground and the engine does not die when it unloads in the air on final approach. I actually like a little bit higher idle in the air, maybe 2100-2400 rpms just to give more prop wash for the rudder in stall turns. To land you probably need to be able to unload the engine and idle back to 1600-1800. I am using the term unload to mean that last little bit of RPM drop that you get as the plane slows on approach and the engine reaches the lowest RPM you get just before landing. My BME engine is a little harder to unload and sometimes I have to pop the nose up sharply on final to get it to idle down and then its fine. Most of the other engines do it on their own,
