Starter box spin direction?
Hello,
I am first off trying to determine which way the flywheel should spin. I am not sure if my starter box is spinning the correct direction. If it is not, how do I change the direction of the wheel rotation in the starter box?
Here is the manual
http://manuals.hobbico.com/dtx/dtxp5700-manual.pdf
Here is the manual
1 Post
RE: Starter box spin direction?
To work out if it's turning the right way mount your car/buggy/truggy on the box and engage the starter motor (you don't need the starter to make contact with the flywheel) it should be easy enough to figure out which way it needs to turn to spin the flywheel clockwise (when viewed from crankcase).
If it's not spinning the correct way just reverse the polarity to the motor.
