Superstar EP battery or ESC problems.
QC, CANADA
When I fly, the motor cuts after about 30 seconds. I can put the throttle at about 50% and it will run another couple seconds before cutting again. Is this because my battery isn't charger properly ? I use an old Hobbico charger that has no 6-7 cells switch. Does by battery HAVE to be charged on a 7-cell charger or a 6-cell charger will do. When I charge it it stays cold, I remember back in the day I ran my RC buggies the battery would get warm as it charged..
QC, CANADA
RE: Superstar EP battery or ESC problems.
Ok one thing at a time then.. how do ESC's work normally ? When the power is too low they cut the motor to leave enough power for the servos to keep working until you land ?
ORIGINAL: iplayloud
