Is there any way to shrink balsa sheet?
Old 08-23-2007, 03:08 PM
longdan
longdan's Avatar
Default Is there any way to shrink balsa sheet?
Is there some way that balsa sheet can be 'shrunk' like covering film? You are probably wondering why I need to do this. I have just finished building a wing. The plans called for 1/16 sheeting on the top of the leading edge only, leaving the bottom open. I don't really like this so I sheeted the bottom with very thin (0.8 mm) sheet, both to add a bit of strength and to preserve the airfoil shape after covering. As with all my models, I painted the balsa with watered down PVA (white) glue to seal the grain and to harden the wood and make it more resistant to dents. The thin sheet soaked up the water and swelled up between the ribs. As it dried, it shrunk a little bit, but not back to its original size. The swelling seems to have occured in one direction only, like it has pushed the grains apart, but not lengthened them. It looks terrible and I think the effects will be very bad. Anybody know any way to bring it back to its original size?
Old 08-23-2007, 03:46 PM
jetmech05
Default RE: Is there any way to shrink balsa sheet?
sand paper applied vigoriously
Old 08-23-2007, 04:40 PM
stang
Hobby knife, apply vigorously.
Old 08-23-2007, 05:33 PM
bigchap
bad temper,applied vigorously!
on a more serious note,no,there is no way of shrinking it,start again.
Old 08-23-2007, 07:05 PM
da Rock
A sanding block that spans 3 or 4 ribs works great if you don't bear down on it. Makes lots of dust but works great.
Old 08-23-2007, 07:39 PM
Jim Thomerson
Try some non plasticized buyterate dope. Several coats and let it dry a day or two between coats. I use the PVA thinned down also but have never used it on sheet that thin.
Old 08-24-2007, 06:22 AM
longdan
longdan's Avatar
Thanks for all the tips (well most of them anyway). I tried the butyrate dope on a small part of the affected area to see if it would work, but it wouldn't soak in due to the PVA I had already sealed it with.
But, for those interested, I managed to almost get it back to how it was. I wet it down again with water, and the balsa swelled like it did before. I then used a piece of very thin perspex with lots of weights on it to press down on the whole surface and left it to dry. It pushed most of the swollen area back to where it should be. Now It just needs a bit of microbaloon filler and a bit of sanding and it will fine.
Old 08-24-2007, 08:46 AM
jeff1127
Next time try sealing both sides before gluing it onto the frame. I know that's a little late for this.
Old 08-24-2007, 09:54 AM
Shuttle RG
80 grit
